Setting the Team Number for the EXP Brain in VS Code
The VEX VS Code Extension enables us to set the team number for the VEX EXP Brain, making it easier to identify which team the Brain is associated with.
Note: While EXP Brains are not legal in a VEX Robotics Competition, assigning team numbers can help to further organize the classroom.
How to set a team number for the EXP Brain in VS Code
  • Connect the Brain to the VEX VS Code Extension. Click on the VEX icon on the VS Activity Bar.
    VEX Robotics Extension icon in the VS Code side menu is highlighted.
  • The VEX view will open in the Side Bar. Hover the mouse over the team item listed under the system subcategory within the VEX DEVICE INFO category in the VEX view. The Pencil icon will appear next to the team item. Click on the Pencil Icon.
    Cursor is hovering over the Team option inside the System folder, and there is a Pencil icon next to it that is highlighted.
  • The Set Team Number window will prompt. Type a new Team Number for the Brain in the Text Box and press the Enter key.
    Set Team Number prompt window with a text field and a message below that reads Press Enter to confirm your input or Escape to cancel.
  • The new Team Number will be set for the Brain.
    Team option is highlighted inside the System folder and it has now been changed to 001.
