AI Classifications are Game Objects that an AI Vision Sensor can detect. These classifications allow the AI Vision Sensor to distinguish between different types of objects in its field of view.
AI Classification Models
There are four different AI Classification Models available for the AI Vision Sensor to use. These Models change what objects the AI Vision Sensor can detect.
Classroom Objects
The Classroom Objects model includes game objects found within the EXP Classroom Bundles and IQ Classroom Bundle.
The AI Classifications include:
- Blue and Red Buckyballs
- Blue, Red, and Green Rings
- Blue, Red, and Green Cubes
In Text-based VEXcode, each of these classifications has an assigned ID which is what is used to differentiate between them in projects.
| Game Object | AI Classification | Python ID | C++ ID |
Blue and Red Buckyballs |
Blue Ball | ClassroomElements.BLUE_BALL | blueBall |
| Red Ball | ClassroomElements.RED_BALL | redBall | |
Blue, Red, and Green Rings |
Blue Ring | ClassroomElements.BLUE_RING | blueRing |
| Green Ring | ClassroomElements.GREEN_RING | greenRing | |
| Red Ring | ClassroomElements.RED_RING | redRing | |
Blue, Red, and Green Cubes |
Blue Cube | ClassroomElements.BLUE_CUBE | blueCube |
| Green Cube | ClassroomElements.GREEN_CUBE | greenCube | |
| Red Cube | ClassroomElements.RED_CUBE | redCube |
Override
The Override model includes game objects for the 2026-2027 VEX V5 Robotics Competition game "Override".
| RedBlue Pin | GameElementsOverride.RED_BLUE_PIN | redBluePin | |
| BlueYellow Pin | GameElementsOverride.BLUE_YELLOW_PIN | blueYellowPin | |
| RedYellow Pin | GameElementsOverride.RED_YELLOW_PIN | redYellowPin | |
| Yellow Pin | GameElementsOverride.YELLOW_PIN | yellowPin | |
| Cup | GameElementsOverride.CUP | cup |
Push Back
The Push Back model includes game objects for the 2025-2026 VEX V5 Robotics Competition game "Push Back".
Red and Blue Blocks |
Blue Block | GameElementsPushBack.BLUE_BLOCK | blueBlock |
| Red Block | GameElementsPushBack.RED_BLOCK | redBlock |
High Stakes
The High Stakes model includes game objects for the 2024-2025 VEX V5 Robotics Competition game "High Stakes".
| Mobile Goal | GameElementsHighStakes.MOBILE_GOAL |
mobileGoal | |
| Red Ring | GameElementsHighStakes.RED_RING |
redRing | |
| Blue Ring | GameElementsHighStakes.BLUE_RING |
blueRing |
Enable AI Classification Detection
To be able to detect AI Classifications, the AI Vision Sensor's Detection Mode must first be enabled in the AI Vision Utility.
Select Configure in the AI Vision Sensor's device menu.
The AI Vision Utility will open. Select the toggle underneath AI Classification to turn on the AI Classification Detection Mode.
Select which AI Classification model to use.
For more information on what AI Classifications are included in each model, go to the "AI Classification Models" section in this article.
Select Close to exit the AI Vision Utility.
You will see the new AI Classification Detection Mode be set to on and the AI Classifications that will be detected are added at the bottom of the AI Vision Sensor's device menu.
Select Done to save your changes to the AI Vision Sensor's configuration.
