Using the V5RC High Stakes Playground Window
The VEX Robotics Competition (V5RC) Virtual Skills Playground is a virtual representation of the V5RC High Stakes (2024-2025) Competition Game. The Virtual Skills High Stakes Playground Window is a space for a virtual version of the Hero Bot, Axel, to play V5RC High Stakes Virtual Skills.
High Stakes Playground Window showing the field at match start
The Pre-Match Checklist
Pre-Match view showing the High Stakes field setup and match control panel
When you open the V5RC Virtual Skills High Stakes Playground Window, the Pre-Match Checklist will open. The default starting position of Axel is at location C, facing the East direction.
The starting location and direction can be edited in the Pre-Match Checklist, by selecting the Edit button for each option.
Robot starting position in the V5RC High Stakes Playground Window
Select A, B, C, or D to choose the starting location. You will see the position of the robot on the Field layout change when the location is changed.
Start direction settings for the robot in the V5RC High Stakes Playground Window
Select North, East, or South to choose the starting direction. You will see the position of the robot on the Field layout change when the direction is changed.
Begin Run button to start a Playground run
Select Begin Run to set your selections and begin your run.
Start Location button for selecting the robot’s starting position in the V5RC High Stakes Playground Window
You can edit the starting position at any time by selecting the Starting Position button.
How to Start, Stop and Reset a Project
Start button to begin a V5RC High Stakes Playground match
Select the Start button to start a project.
This button will change to a Stop button when a project is actively running.
Stop button to end the V5RC High Stakes Playground simulation
Selecting the Stop button will stop the project and the timer immediately.
The Score Window will appear at this time. See below for more information on the Score Window.
Reset Playground Window icon
Select the Reset button to reset the timer, point value, and Field.
How to View Your Score and the Timer
Score display with red and blue alliance scores, match timer, and match status
Your score can be seen above the Field on the left side. This will be updated in real-time after the project is started.
Match timer showing autonomous and driver control periods in the V5RC High Stakes Playground window
The timer is located above the Field on the right side.
The timer begins when a project is started and counts down from 1:00. The timer will count down until Stop is selected, the Stop project block is used in the project, or the timer reaches 0 seconds.
Viewing the AI Vision Sensor Snapshot Window
AI Vision button in the Playground Window
The virtual Hero Bot, Axel, is equipped with an AI Vision Sensor. To view the Snapshot Window and see the data the AI Vision Sensor is reporting, select the AI Vision Sensor button.
Select the AI Vision Sensor button again to hide the Snapshot Window.
V5RC High Stakes Playground window showing the AI Vision Snapshot view
The Snapshot Window will open in the upper right hand corner of the Playground. Data from the AI Vision sensor is best viewed with Axel's arm raised, as shown here.
To learn more about using the AI Vision Sensor in V5RC High Stakes Virtual Skills, see this article.
How to Retry and Close the Score Window
V5RC High Stakes Playground Window with Skills Match controls and settings
The Score Window appears when the timer reaches 0, or if the project is stopped.
The Score Window shows your team's name, number, total score, and Skills Stop Time.
Retry button to restart the High Stakes Playground Window simulation
Select the Retry button to return to the Field and reset the timer and score.
Match results shown in the V5RC High Stakes Playground window
Select the X in the top-left corner to close the Score Window and return to the Field.
This will not reset the Field, timer, or score. It will return to the Field exactly as it was at the moment the project was stopped.
How to Expand and Shrink the Playground Window
V5RC High Stakes Playground Window with field controls and match setup options
The window begins at a smaller size by default. If you want to expand the window, select the Expand button at the top left corner.
VEXcode VR Playground window for the V5RC High Stakes game field
Select Shrink in the top-left corner to return the window to the default size.
How to Hide and Show the Playground Window
Hide button to collapse the V5RC High Stakes Playground window
Select the Hide button to collapse the V5RC Virtual Skills Window. This will still keep the toolbar at the top of the window visible.
Show button to open the High Stakes Playground window
To view the full window again, select the Show button.
How to Select Different Camera Views
Top view showing the V5RC High Stakes Playground Window camera position
Select the Top Camera button to see an overhead view of the entire Field. This is the default view when you open the V5RC High Stakes Playground Window.
Camera chase view following the robot in the V5RC High Stakes Playground Window
Select the Chase Camera button to see a behind-the-robot view.
Orbiting the camera view around the V5RC High Stakes Playground scene
Select the Orbit Camera button to see an overview of Axel and the full Field.
How to View Settings
Playground Window controls for field side, autonomous settings, and match timing
Select the gear icon to open the Settings window.
High Stakes Playground Window settings for selecting a challenge and resetting the field in VEXcode VR
Data about your device will be displayed in the Settings window. This can be used to help troubleshoot any performance issues.
