An Introduction to Axel: The V5RC High Stakes Hero Bot
View the VEX V5 High Stakes Hero Bot "Axel" Parts 1&2 Videos here:
VEX V5 High Stakes | Hero Bot "Axel" | Part 1
VEX V5 High Stakes | Hero Bot "Axel" | Part 2
Each year, the V5 Hero Bot is designed from the VEX V5 Competition Starter Kit to provide teams with a starting point to play the current VEX Robotics Competition game. Hero Bots are designed using the Competition Kit pieces in a way that the robot can be disassembled at the end of the season and made into the next Hero Bot with the same Kit. Experienced teams are able to quickly assemble a robot to investigate the game's dynamics. New teams can also use the Hero Bot to learn valuable building skills and have a robot they can customize to compete with early in the season.
The 2024-2025 VRC Game is High Stakes. This season's Hero Bot to play High Stakes is Axel. You can view Axel’s build instructions for more information. Starting layouts of the game Field differ depending upon which match you are playing and the level (V5, VEX U, or VEX AI). Learn more about this year's game by viewing this article.
Scoring Capabilities
Ring game pieces for the V5RC High Stakes game are shown scored on the Stake of a Mobile Goal.
Mobile Goals
Axel earns points by scoring Rings on Stakes throughout the game Field. Axel can pick up and lift Rings using its robotic arm, and Axel can push the Rings onto Stakes using its Pusher component. Mobile Goals are placed at various locations around the Field, and each Mobile Goal can fit 6 Rings.
Using its outward-facing C channel, Axel can push Mobile goals to different locations on the Field to score additional points or deduct points from a component.
On the top of every Stake there is a rubber cap; this cap retains the rings on the Stakes, which is especially important for the Mobile Goals as they move around the Field.
Ring game pieces for the V5RC High Stakes game are shown scored on a Wall Stake.
Wall Stakes
Axel can use its robotic arm to pick up and place rings on the four Wall Stakes around the perimeter of the Field. There are two Alliance-specific Stakes and two Neutral Stakes.Alliance Wall Stakes can hold 2 Rings each, while Neutral Wall Stakes can hold 6 Rings each. Rings can be scored on any Neutral Stake at any time.
Ring game piece for the V5RC High Stakes game is shown scored on a High Stake on the Ladder.
Ladder
With significant modifications, Axel can use its robotic arm to climb the Ladder to score a Ring on the High Stake at the top of the Ladder. These High Stakes can fit only one Ring each.
View of the High Stakes game field with the Ladder in its center.
Axel can earn additional points by using its robotic arm to climb the Ladder at the end of the game. There are no alliance-specific climbing locations on the Ladder, allowing alliances to climb from any side of the Ladder to score points.
Scoring Modifications
Top down view of the High Stakes game field with the Positive Modifiers in two of the corners highlighted.
Positive Modifiers
At any point in the match, Axel can use its C-channel to push Mobile Goals into the 4 corners of the Field, called Modifiers.
Two of the Modifiers are positive (+). When Axel pushes a Mobile Goal into a Positive Modifier, all Rings on that goal will double in point value.
Top down view of the High Stakes game field with the Negative Modifiers in two of the corners highlighted.
Negative Modifiers
The other two Modifiers are negative (-). When Axel pushes a Mobile Goal into a Negative Modifier, all Rings on that goal will be changed to negative point values.
Two blue Ring game pieces for the V5RC High Stakes game are shown scored on a Wall Stake.
Descoring
Axel can descore Rings from an opponent by removing Rings from the Stakes. Caps at the top of the Stakes make descoring Rings slightly more challenging than scoring them.
Design Features
Axel is designed to be quick to build and easy to drive. The robot has several key features that enable it to complete some of the tasks in the High Stakes game.
Note:As a starting point for your competition robot, Axel is designed to help students, teachers, and coaches quickly complete a robot to begin understanding the game. Axel is not designed to be extremely competitive and cannot perform every task in the High Stakes game.
View of the Axel build from below to highlight the 2 motors that power its 2 Omni-Directional driving wheels directly.
2-Motor Direct Drive Drivetrain
Axel has a four wheel, two motor, drivetrain, allowing Axel to easily maneuver around the High Stakes Field.
The drivetrain operates as a two-wheel direct drive drivetrain, as the shaft stretches directly from the motor to the wheels without using gears or a chain and sprocket system.
The two motors power the front wheels, making this a front-wheel drive robot.
For more information on drivetrains, view this article from the VEX Library.
Angled view of the Axel build to highlight its two Omni-Directional Wheels.
Two of the drivetrain’s wheels are Omni Directional Wheels. These wheels have rollers around the circumference of the wheel, which allows the wheel to roll both forwards and backwards, as well as left and right.
Omni Directional Wheels enable the robot to turn easily to navigate the High Stakes Field. The Omni-Directional Wheels also allow more advanced drivetrain designs that can maneuver in complex ways over obstacles.
Rear view of the Axel build to highlight its two Rubber Traction Wheels.
The other two wheels on the drivetrain are rubber traction wheels. These wheels have rubber traction that allow them to grip the surface of the Tiles to reduce any drift that could be caused by the Omni-Directional Wheels during turns.
The rubber traction on the wheels keeps the orientation of the robot straight and stable, and the greater the traction of a wheel, the harder the robot can push or pull, and the easier it is for the robot to travel over obstacles. These wheels create smoother movement and improved grip on the Tiles.
Front view of the Axel build to highlight its Outward-Facing C Channel.
There is no frame opening on Axel, but the front of the robot contains an outward-facing C Channel. This channel is placed on the robot at a critical height to help interact with and push the Mobile Goals around the Field.
The C channel adds rigidity and strength to the robot's frame, enabling it to handle the force of pushing the Mobile Goals as well as keep the Goals aligned correctly while being transported. This design also allows for different parts to be easily attached or removed from the robot as needed during the design process.
Angled view of the Axel build to highlight its Robotic Arm mechanism.
Robotic Arm
The third motor on Axel controls the arm. This arm helps Axel to grab rings, lift rings onto Stakes, and then climb up the Ladder at the end of the match. The arm is a single gear reduction, one axis arm that can move approximately 90 degrees. Single gear reduction means that the gear system only uses one set of gears to achieve speed reduction; by reducing the speed, the torque of the arm is increased, empowering the arm to lift heavy objects.
Using its axis, the arm can move up and down and its simplicity will allow it to achieve high precision of movement. To climb the Ladder, you can simply lift the arm, drive onto the first rung, and then lower the arm, which will lift the robot off the ground.
Angled view of the Axel build to highlight the Pusher mechanism on its Robotic Arm.
Pusher
The fourth motor on Axel controls the Pusher, the mechanism that pushes the Rings off the end of the arm. The Pusher consists of passive intake flaps at the end of the arm that hold the Rings as the arm rotates. To push the Rings off the Arm, the fourth motor powers the intake flaps, which push the Rings off the arm to score them onto the Stakes.
Controlling Axel
The Drive Program built in the V5 Brain is compatible with Axel but can be improved. For example, consider adding sensors to your robot to enable Axel to perform specific tasks autonomously depending on the location of detected objects on the Field or detected actions.
Modifying Axel
There are several ways that you might consider modifying Axel:
Angled view of the Axel build.
You could change the geometry of Axel's robotic arm to pick up Rings more easily. You could also enable mobile goal manipulation to enable Axel to transport Mobile Goals across the Field using complex maneuvers.
An effective way to modify Axel could be through adding sensors. Sensors can be used to enable Axel to perform autonomously based on specific detected objects or actions.
Adding Your License Plate
Angled view of the Axel build with a license plate added to the side of its Robotic Arm.
<R10> of the V5RC High Stakes Game Manual states the following:
“To participate in an official VEX V5 Robotics Competition event, a Team must first register and receive a V5RC Team number.
This Team number must be displayed on the Robot using license plates.
Teams may choose to use the official V5RC License Plate Kit, or may create their own.
License plates must be placed on a minimum of two (2) horizontally opposing sides of the Robot (i.e., the top of a Robot is not considered a “side”), and must remain visible and attached for the entirety of the Match.
The image to the left shows one possible mounting location. The mounting location you choose should abide by <R10> of the Game Manual.
Cutting Metal
Diagram of a 12 inch Shaft piece with a red line drawn over it to indicate cutting it to customize its length.
Although Axel is designed to be built without needing to cut pieces, in order to participate in the V5RC competitively, cutting metal to create custom pieces is certainly recommended.
As a starting place, look at the 12 inch Shaft used on the arm. It may be a good idea to trim this shaft, as shown in the image to the left, for the purpose of streamlining your build.
What other pieces do you think should be cut for the purpose of improving your build? Remember, the use of cutting pieces allows for immense customization with your robot, but ensure you are doing this safely with supervision. For more information, see Precautions and Safety Guidelines When Working with V5 Robots.
Still not sure where to start? Check out the article, Getting Started with the 2024-2025 V5RC Robot Design: High Stakes for more information on how to use Axel as a starting point.
