Understanding CTE Workcell Conveyors
The CTE Workcell Conveyors are designed to emulate the function and characteristics of real-world conveyors within the manufacturing industry. These conveyors can be used to transport Disks to different sections of the VEX CTE Workcell.
Complete CTE Workcell build.
The CTE Workcell Kit includes two types of conveyors: The Linear Conveyor and the Serpentine Conveyor. Read more about each conveyor and their respective components below.
For instructions on how to build the Linear and Serpentine Conveyors, see the CTE Build Instructions.
Linear Conveyor
Two pieces of linear conveyor components connected together.
The Linear Conveyor is designed to transport materials in a straight line, or linearly, using the conveyor belt. Within manufacturing operations, linear conveyors often serve as an intermediary between more complex sections of a larger conveyor.
CTE Workcell conveyor showing how parts move along the belt in the context of the larger build.
Within the VEX CTE Workcell, the Linear Conveyor serves as the entry and exit point for Disks, passing them onto and off of the larger Serpentine Conveyor. The Disk Loader can attach to the Linear Conveyor to load Disks onto the Workcell.
Linear Conveyor Components
The Linear Conveyor contains the following components:
Individual linear conveyor component.
Linear Conveyor
The Linear Conveyor consists of a conveyor belt inside the conveyor support structure. Gears are located inside the support structure. When connected to the motor, these gears turn, setting the conveyor belt in motion.
The same linear conveyor component, connected to a motor with a shaft.
Each Linear Conveyor system requires one Linear Conveyor to be connected to a 5.5w Motor. The motor rotates the gears in the conveyor, causing the belt to move.
Plastic disk loader piece.
Disk Loader
The Disk Loader holds the Disks waiting to be released onto the conveyor. The Disk Loader can be used either with the Linear Conveyors or with the Feeder Base and Disk Feeder, to dispense Disks using pneumatic controls.
To read more about how pneumatics can be used to automate the transport and sorting of Disks, review the article, Understanding CTE Workcell Pneumatics
The Serpentine Conveyor
CTE Workcell serpentine conveyor showing the main belt, rollers, and support frame components.
The Serpentine Conveyor, also called a snake or spiral conveyor, consists of interconnected belts and platforms arranged in a series of twists and turns, resembling a snake-like shape. These conveyors are designed to maximize the use of available space.
Serpentine Conveyor Components
The Serpentine Conveyor contains the following components:
Chain and Platforms
The Chain and Platforms make up the moving components of the Serpentine Conveyor.
Serpentine conveyor chain pieces connected in a long winding line.
Serpentine Conveyor - Chain
The Chain consists of connected Links. The Chain in the CTE Workcell Kit begins with contains 80 Links. The length of the Chain can be modified to meet the needs of your build. See this article for information on making a custom Serpentine Conveyor.
The Chain connects the surface of the conveyor (the Platforms) to the Track, including a Sprocket, in order to control the movement of the conveyor.
Serpentine conveyor platform piece shaped like a half moon.
Serpentine Conveyor - Platform
The Serpentine Conveyor - Platform is the surface of the conveyor that interacts with objects. These pieces snap onto the surface of the Chain.
Track Pieces
Track pieces are sections of the Serpentine Conveyor base used to connect devices to the conveyor and the conveyor to the CTE Tiles.
Serpentine conveyor straight track piece.
Serpentine Conveyor - Straight Track
The Serpentine Conveyor - Straight Track is a section of the conveyor that maintains a straight path.
Serpentine conveyor turn track piece that is curved.
Serpentine Conveyor - Turn Track
The Serpentine Conveyor - Turn Track creates a 90 degree turn for the conveyor.
Serpentine conveyor drive track piece.
Serpentine Conveyor - Drive Track
The Serpentine Conveyor - Drive Track is the piece with mounting locations for a 5.5w motor and Sprocket. These connected to and power the rotation of the Chain, which in turn moves the Platforms.
Serpentine conveyor diverter track piece.
Serpentine Conveyor - Diverter Track
The Serpentine Conveyor - Diverter Track includes a mounting location for the Pneumatic Diverter Tower to redirect or sort items to different paths or destinations within the larger conveyor. The other side of this track includes an opening for Disks to move off of the conveyor onto another system.
