Allow Camera Permissions for AI Vision Sensor on Chrome Browser VEXcode EXP
When configuring your AI Vision Sensor in Web-based VEXcode V5, the computer will ask for permission to use your camera. If you select Block instead of Allow, the AI Vision Sensor will not be able to connect to VEXcode. To fix this issue, follow the steps below:
Settings icon next to the Chrome search bar is highlighted.
1. Select the settings icon to the left of the page’s URL.
Chrome Site Information dropdown menu is open, showing settings for the codeexp.vex.com website. The Reset Permissions option is highlighted in the menu.
2. Select Reset Permission.
Chrome prompt below the search bar that reads Reload this page to apply your updated settings on this site. To the right of the prompt there is a blue Reload button that is highlighted.
3. A prompt to reload the page will appear. Select Reload.
Chrome camera permission prompt that reads codeexp.vex.com wants to use your camera. Below, there are two buttons reading Allow and Block. The Allow button is highlighted.
4. Return to the AI Vision Utility. You will now be able to connect the AI Vision Sensor again and select Allow.
