Understanding the User Settings for VEX VS Code Extension
User Settings are global settings that Visual Studio Code offers for each extension. The VEX User Settings allow us to configure the VEX Extension according to our own requirements and are applied to every VEX VS Code extension project.
Accessing the VEX User Settings in VS Code
  • Click on the Setting Icon at the bottom left of the VS Code User Interface.
    Settings icon at the very bottom of the VS Code Activity Bar, located in the bottom left corner of the screen.
  • The Context Menu will prompt. Click on the Settings item.
    VS Code Settings context menu with many options listed. An option reading Settings is highlighted and is the third option in the menu, below Command Palette and Profiles.
  • The Settings window will prompt.
    VS Code Settings window is open and shows the Commonly Used settings article by default.
  • Click on the Extensions item in the left-hand list view of the Settings window to extend the list of Extensions and view its items.
    VS Code Settings Window is open and the Extensions category is highlighted on the left-hand navigation list.
  • Scroll down the list view to the bottom and click on the list item VEX.
    VS Code Settings Window is open and the VEX page link inside the Extensions category is highlighted.
  • The VEX User Settings will appear in the right-hand panel.
    VS Code User Settings is opened to the VEX page where the behavior of the VEX Robotics Extension can be customized.
VEX User Settings Overview
  • Controller: Channel (V5 Controller only)
    The Controller: Channel setting controls the radio communication channel type between a V5 Brain and a V5 Controller. This setting only applies when VS Code is connected to a V5 Controller via USB and the controller is connected to a V5 Brain via VEXnet.
    To set the V5 Controller Radio Channel, click on the Drop-down Menu and select between Download and Pit.
    • Download - When set to Download, the radio will jump to a download VEXnet channel once a user program download is initiated. The download channel allows for higher data rates and more efficient downloads.
    • Pit - When set to Pit, the radio will remain on a pit channel, and the download will take much longer.
    Note: By default, the V5 Controller Radio Channel is set to Download.
    VEX User Settings with the Controller Channel option shown. This option has a dropdown menu that is set to Download by default. The description reads Sets V5 Controller Radio Channel. This setting applies to VEXnet radio link only.
  • Cpp SDK: Home
    The Cpp SDK Home setting sets the home directory of the C++ SDK (Software Development Kit). This setting defines the location on the computer where the C++ SDK is installed.
    Note: DO NOT EDIT THIS SETTING.
    VEX User Settings with the Cpp SDK Home option shown. This option has a link that reads Edit in settings.json. The description reads DO NOT EDIT.
  • Cpp Toolchain: Path
    The Cpp Toolchain Path setting sets the Path for the toolchain that is used when building a C++ VEX VS Code project.
    To set the Cpp Toolchain Path, type the Path to the toolchain on the computer in the Text Box.
    VEX User Settings with the Cpp Toolchain: Path option shown. This option has a text field that represents a File Path. The description reads Path to toolchain.
  • General: Enable User Terminal
    The Enable User Terminal setting allows the VEX Extension to open the user serial port when a VEX Brain or VEX Controller is detected by the extension. The only exception applies to a V5 Controller which does not enumerate with a user serial port.
    To set the Enable User Terminal setting, click on the Drop-down Menu and select between Enable and Disable.
    • Enable - Enable allows the VEX Extension to connect to a user port on startup and will create the Interactive Terminal. If Enable is selected while the extension is running, the extension will try to open the user port if a device is connected.
    • Disable - Disable prevents the VEX Extension from connecting to the user port on startup and won’t create an Interactive Terminal. If Disable is selected while the extension is running, the extension will close the user port and remove the Interactive Terminal.
    Note: By default, the Enable User Terminal setting is set to Enable.
    VEX User Settings with the General Enable User Terminal option shown. This option has a dropdown menu that is set to Enable by default. The description reads Enable extension to open and display data from the user port.
  • General: Log Entries
    The Log Entries setting sets the number of log entries to upload from a VEX Brain.
    To set the number of log entries, type the number in the Text Box.
    Note: By default, the number of log entries is set to 1000.
    VEX User Settings with the General Log Entries option shown. This option has a text field that is set to the number 1000 by default. The description reads Sets the number of log entries to upload from a VEX Brain.
  • Project: Build Type
    The Project: Build Type setting sets how the VEX Extension will build a C++ project.
    To set the Cpp Project Build Type, click on the Drop-down Menu and select between Build and Rebuild.
    • Build - Build only builds the project when any changes in the project’s source code are detected.
    • Rebuild - Rebuild cleans the project’s build directory, then builds the project. This option is much slower.
    Note: By default, the Cpp Project Build Type is set to Build.
    VEX User Settings with the Project Build Type option shown. This option has a dropdown menu that is set to Build by default. The description reads Set Cpp Project Build Type.
  • Project: Home
    The Project: Home setting sets the default home directory for a new project when completing the New Project wizard.
    To set the default location for new projects, type the directory on the computer in the Text Box.
    VEX User Settings with the Project Home option shown. This option has a text field that represents a File Path. The description reads Sets the default location for new projects.
  • Project: Run After Download
    The Project: Run After Download setting sets if the user program should run after downloaded to a VEX Brain.
    To set the user program to run after it has been downloaded to the VEX Brain, select the Check Box. To set the user program not to run after the download, unselect the Check Box.
    Note: By default, the Check Box next to the Project: Run After Download setting is unselected.
    VEX User Settings with the Project Run After Download option shown. This option has a check box that is unselected by default. The description reads Set if user program should run after download.
  • Python: SDK Home
    The Python SDK Home setting sets up the home directory of the Python SDK (Software Development Kit). This setting defines the location on the computer where the Python SDK is installed.
    VEX User Settings with the Python SDK Home option shown. This option has a link that reads Edit in settings.json. The description reads DO NOT EDIT.
  • System DFU: Auto Recover
    The System DFU Auto Recover setting sets if the Brain should automatically recover when an IQ (2nd) Brain or an EXP Brain is detected in DFU (Device Firmware Update) mode.
    To set the Brain to automatically recover when an IQ (2nd) Brain or an EXP Brain is detected in DFU mode, select the Check Box. Otherwise, unselect the Check Box.
    Note: By default, the Check Box next to the System DFU: Auto Recover setting is selected.
    VEX User Settings with the System DFU Auto Recover option shown. This option has a check box that is selected by default. The description reads Set if brain should auto recover when an IQ2 or EXP is detected in DFU mode.
  • Websocket Server: Enable
    The Websocket Server: Enable setting enables the VEX Extension to start the Websocket Server, which allows the real-time data transfer between the Server and the VEX device.
    To set the Websocket Server: Enable setting, click the Drop-down Menu and select between Enable and Disable.
    • Enable - If Enable is selected, the VEX Extension will start the Websocket Server, which allows the user access to a two-way pipe to the selected VEX device. The Websocket Server can be accessed at `ws://[ip]:[port]/vexrobotics.vexcode/device`.
    • Disable - If Disable is selected, the VEX Extension will not start the Wesocked Server.
    Note: By default, the Websocket Server: Enable setting is set to Disable.
    VEX User Settings with the Websocket Server Enable option shown. This option has a dropdown menu that is set to Disable by default. The description reads Enables extension to start Websocket Server. Server allows user access to a two-way pipe to the selected VEX device. Websocket can be accessed at ws://[ip]:[port]/vexrobotics.vexcode/device.
  • Websocket Server: Host Address
    The Websocket Server: Host Address setting sets the host address of the WebSocket Server. The Websocket Server is hosted on the computer that the VEX Extension is running on. The Websocket Server Host Address is the IP address for accessing the Websocket Server at `ws://[ip]:[port]/vexrobotics.vexcode/device`.
    To set the Host Address, type the host address (IP address) in the Text Box.
    VEX User Settings with the Websocket Server Host Address option shown. This option has a text field that is set to an address of 0.0.0.0 by default. The description reads Sets Host Address.
  • Websocket Server: Port
    The Websocket Server: Port setting configures the Port Number of the Port that the Websocket Server is running on. The Port Number can be used for accessing the Websocket Server at `ws://[ip]:[port]/vexrobotics.vexcode/device`.
    To set the Websocket Server Port Number, type the port number in the Text Box.
    VEX User Settings with the Websocket Server Port option shown. This option has a text field that is set to the number 7071 in this example. The description reads Sets Websocket Server Port Number.
