Data Logging with VEX Brain/Sensors (Python Version)
Introduction
In this article, we will discuss how to create a data logging project that instructs the VEX Robot to collect data with the VEX Brain and save it in a CSV file on the SD card for data analysis.
Data logging is a powerful tool that we can use to assist scientific research, conduct our own experiments, and solve specific problems. There are various fun and exciting tasks that we can drive the VEX Robot to accomplish with data logging. The following are some examples:
  • Gathering data with the Distance Sensor to calculate the speed of the robot
  • Driving the robot around the classroom and collecting data with the Optical Sensor to observe light changes in various locations.
  • Taking the robot on an adventure and recording GPS coordinates data to create a map.
Coding skills needed for developing a Data Logging Project
  • Use various commands to collect data with VEX Brain/Sensors and add it to a data structure.
  • Write the data to a Comma-Separated Values (CSV) file on the SD card.
Hardware Required for Data Logging:
  • A VEX Brain (IQ, V5, EXP)
  • A SD card
  • A Sensor or multiple Sensors (Optional, according to the required data)
Getting Data From The Sensor
We can program the VEX Robot (IQ, V5, EXP) to capture the data from the following sensors:
  • Inertial Sensor
  • Distance Sensor
  • Optical Sensor
  • Vision Sensor
  • Rotation Sensor (V5, EXP)
  • GPS Sensor (V5)
Note: the VEX IQ (2nd generation) Brain and the VEX EXP Brain have an Inertial Sensor built in. We can collect the Inertial Sensor data with these VEX Brians.
In this article, we will develop a data logging project that collects the acceleration data with the VEX IQ Brain (2nd) and stores it into an SD card.
First, we need to write a short program to get readings from the Timer and the Inertial Sensor built in the VEX IQ Brain (2nd).
  • At the beginning of this program, we will need to import the Python modules to control VEX IQ Brain (2nd) and fetch the data from it. Thus, start by adding these instructions to the project.
  • # Library imports
    from vex import *
    # Brain should be defined by default
    brain = Brain()
    brain_inertial = Inertial()
  • Next, add the code to declare a variable numOfDataEntries to store the number of data entries for recording, declare a variable polling_delay_msec to store the value of time interval for reading data, and create an empty string variable data_buffer to store the data read from the sensor.
  • numOfDataEntries = 100
    polling_delay_msec = 50
    data_buffer = ""
  • As we will use the current value of the Timer to add the Timestamp to the data, we need to reset the timer value back to 0 seconds before starting collecting data.
  • # Add timer initialization code
    brain.timer.clear()
  • Before using the instruction that fetches the data from the VEX IQ Brain (2nd) and records the data in the buffer, we need to understand it first.
    The following instruction appends the current timer value to the data_buffer variable in a specific format.
    A line of Python code is highlighted in pieces to explain it in detail. The line of code reads data_buffer += 1.3f % brain.timer.value() + comma. First, the += operator is highlighted and labeled Append data to the data_buffer string. Next, the 1.3f string is highlighted and labeled Format string. Next, the percent sign is highlighted and labeled String modulo operator. Next, the brain.timer.value() command is highlighted and labeled The current value of the timer. Lastly, the addition of the comma string at the end is highlighted and reads Add a comma at the end to separate data.
    Let’s break down the format string “%1.3f”:
    • “%”: Introduces the conversion specifier.
    • “1”: Indicates the minimum number of digits to be present in the string
    • “.3”: Specifies the number of decimal places to include in the formatted number.
    • “f”: Indicates that the value to be formatted is a floating-point number.
    Thus, we can use the format string “%1.3f” to format a floating-point number with a minimum width of 1 digit and a precision of 3 decimal places.
  • Now, we can read the Timer and the acceleration value of the Inertial Sensor built in the VEX IQ Brain (2nd) and then append the data to the data_buffer variable in the specified format.
  • # Commands to write the data to buffer
    data_buffer += "%1.3f" % brain.timer.value() + "\n"
    data_buffer += "%1.3f" % brain_inertial.acceleration(XAXIS) + ","
    data_buffer += "%1.3f" % brain_inertial.acceleration(YAXIS) + ","
    data_buffer += "%1.3f" % brain_inertial.acceleration(ZAXIS) + "\n"
    The previous code is explained in detail. The first data_buffer line using brain.timer.value() is labeled Add Timestamp to buffer. The next three lines are labeled Add the acceleration value along the X, Y, and Z axes to buffer.
    Note: “\n” is the New Line character. It indicates that the line ends here and the beginning of a new line.
  • Then, to record a certain number of data entries into the data_buffer variable, we can use a for loop to repeatedly execute the instructions that fetch the data and append the data to the data_buffer variable for a number of iterations. Our strategy is to use the value of the variable numOfDataEntries to determine the number of iterations.
  • # Data Generation
    for i in range(0, numOfDataEntries):
  • So far, our program records data as quickly as it possibly can. However, we want to record data at specific time intervals. Therefore, we can use a wait() function in the for loop to pause the program to add the specific time interval between two readings. We use the value of the variable polling_delay_msec to determine the value of the time interval.
  • # Data Generation
    wait(polling_delay_msec, MSEC)
Congratulations! We've finished the program to get readings (the acceleration data) from the Inertial Sensor built in the VEX Brain. Next, we will explore how to write the data to a CSV file on the SD card.
# Library imports
from vex import *
brain = Brain()
data_buffer = ""
brain.timer.clear()
# Data Generation
Attaching the SD Card to the VEX Brain
Before writing the data to a file on an SD card, insert the SD card into the SD card slot of the VEX Brain first.
EXP Brain is shown with its SD card slot highlighted. The SD card slot is on the side of the Brain, to the right of its USB-C port.
Note: Format the SD card to FAT32 for data writing. We recommend using SD cards that are 32GB or less in size.
To ensure that writing data to a file on the SD card can be performed under appropriate conditions, we will need to add code to check if the SD card is properly inserted into the VEX IQ Brain (2nd).
  • Use the brain.sdcard.is_inserted() function to check if the SD card is inserted. If the SD card is not inserted, display the corresponding message on the VEX IQ Brain Screen and hold the program.
  • # Hold the program if the SD card is not inserted
    if not brain.sdcard.is_inserted():
    brain.screen.set_cursor(1,1)
    brain.screen.print("SD Card Missing")
    while(True):
    wait(5, MSEC)
    Note: the brain.sdcard.is_inserted() function returns True if an SD card is inserted into the Brain.
Writing the Data to a CSV file on the SD Card
So far, our program can collect data with the VEX IQ Brain (2nd). To complete the data logging project, we need to write the data to a Comma-Separated Values (CSV) file on the SD card for future examination and analysis.
  • When writing different types of data to a CSV file, we want to know which type of data each column contains. To do this, we can append the CSV header text to the data_buffer variable before recording data.
    Thus, add the code to declare a variable csvHeaderText to store the CSV header text to specify the column names for the CSV file and declare a variable sd_file_name to hold the name of the CSV file to write on the SD card.
  • csvHeaderText = "time, x, y, z"
    sd_file_name = "myDataPY.csv"
Note: Make sure the headers are in the same order as the data stored in the data_buffer variable.
  • Next, append the CSV header text to the data_buffer string before the for loop for data collection.
  • # Create CSV Header
    data_buffer = csvHeaderText + "\n"
    # CSV Data Generation
  • Before writing data to a file on the SD card, let’s get to understand how to use the brain.sdcard.savefile() function first.
    A line of Python code is highlighted in pieces to explain it in detail. The line of code reads brain.sdcard.savefile(sd_file_name, bytearray(data_buffer, 'utf-8')). First, the brain.sdcard.savefile section is highlighted and labeled Save a bytearray into a named file on the SD card. Next, the sd_file_name section is highlighted and labeled Filename. Lastly, the bytearray(data_buffer, 'utf-8') at the end is highlighted and labeled Buffer.
    This instruction writes the data stored in the data_buffer variable to a named CSV file on the SD card.
    Let’s break it down:
    • brain.sdcard.savefile(): The function saves a bytearray into a named file on the SD card. The function returns the number of bytes written to the file.
    • sd_file_name: The first parameter of the function. Indicates the name of the file to write. In this project, the file name is stored in the variable sd_file_name.
    • bytearray(datat_buffer,’utf-8’): The second parameter of the function. Represents the bytearray to be written into the file.
        • bytearray(): The method creates a mutable bytearray. In this instruction, we use it to convert a string to a bytearray by specifying the encoding.
        • data_buffer: The first parameter of the method. Indicates the source to be converted to a bytearray. In this project, the source is the data stored in the variable data_buffer.
        • ‘utf-8’: The second parameter of the method. Indicates the specified encoding used to encode the string. The encoding is ‘utf-8’ in this instruction.
  • After the for loop for data collection, use the brain.sdcard.savefile() function to write the data stored in the data_buffer variable to the CSV file on the SD card. In addition, add the code to check the return value from the brain.sdcard.savefile() function to verify if the data has been written to the file successfully and display the corresponding message on the VEX IQ Brain Screen to get real-time feedback.
  • # CSV Data Generation
    # Write the data to SD Card
    brain.screen.set_cursor(4,1)
    if brain.sdcard.savefile(sd_file_name, bytearray(data_buffer,'utf-8')) == 0:
    brain.screen.print("SD Write Error")
    else:
    brain.screen.print("Data Written")
    Note: The brain.sdcard.savefile() function returns the number of bytes written to the file. In this project, we use it to write the collected data to a CSV file, so the number of bytes written to the file must be greater than zero. In other words, if the brain.sdcard.savefile() function returns 0, we can conclude that the data hasn't been written to the file successfully. Otherwise, the data has been written in the file.
Congratulations! We've developed a data logging project that collects the acceleration data with the VEX IQ Brain (2nd) and stores it into a CSV file on the SD card. Next, we will explore how to open the CSV file for data analysis.
# Library imports
from vex import *
brain = Brain()
data_buffer = ""
while(True):
wait(5, MSEC)
# Add any sensor & timer initialization code here
brain.timer.clear()
# Create CSV Header
data_buffer += "%1.3f" % brain.timer.value() + ","
else:
Opening the CSV File for Data Analysis
Once the data has been written to the CSV file on the SD card, we can use a spreadsheet application to open the file for reading and analyzing the data.
Note: Two of the most common spreadsheet applications are Google Sheets and Microsoft Excel. In this article, we will use Google Sheets (Web Based) to open the CSV file on the SD card. The process of using other applications is similar.
  • Remove the SD card from the VEX IQ Brain’s SD card slot. If the computer has a built-in Micro SD card slot, we can insert the SD card directly into that slot. Otherwise, insert the SD card into an SD card adapter and then connect the adapter to the computer.
  • Log in to our Google account and open Google Sheets. Create a new spreadsheet.
  • In the spreadsheet, open the “File” menu, select “Import” -> “Upload” -> “Browse” button, then choose the CSV file on the computer. After uploading the CSV file, click the “Import Data” button. After Importing data, click “Open now” to see the collected data in the CSV file.
    Project's CSV data opened in a Google Sheets document. There are four columns reading Time, X, Y, and Z. There are many rows of data that document the acceleration at each time stamp.
  • (Optional) One easy way to analyze the data is to draw a graph, and then look for the trends in the data. In the spreadsheet, open the “Insert” menu and select “Chart” to draw a graph using the data in the CSV file. The following graph is the result of the acceleration data collected with the VEX IQ Brain (2nd).
    Chart of the data is opened in Google Sheets, showing the acceleration of the X, Y, and Z axes over time. The Z value stays near negative one, and the X and Y values stay near zero.
    Note: We can use the Chart editor to select a different Chart Type or edit the chart based on our needs.
Up to this point, we've finished the data logging project that collects data with the VEX IQ Brain (2nd) and saves it in a CSV file on the SD card. Also, we have learned how to read the CSV file on the SD card using Google Sheets and even create a graph for further analysis. What next? Let’s try to plan more exciting experiments using the VEX Robot for data logging, to observe how the changing environmental factors affect various types of data and get a deeper understanding of the world around us.
