Certificates earned through certifications.vex.com have been moved to the VEX Professional Development Plus (PD+) system, with the shutdown of the certifications.vex.com website. You can still access your certification, but will need to print a new certificate in order to have a working QR code to verify your certification.
This article will walk you through how to access your certificate in PD+ to reprint it.
Accessing Your Certificate from certifications.vex.com in PD+
Navigate to pd.vex.com and select 'Login' in the upper right hand corner.
Log into PD+ using the same credentials you used to access certifications.vex.com.
Once logged in, you will be taken to your PD+ Dashboard.
Certification information is located on the right hand side of the Dashboard, as shown here.
Select 'View All Certificates' to view certificates that you have earned.
Select 'Download' beneath the certificate you wish to print, to download the certificate for printing.
This new certificate has an active QR code that can be used to verify your certification.
