Accessing VEX EXP STEM Lab Videos for Export
The videos in VEX EXP STEM Labs are an essential resource for educators and students using VEX STEM Labs.  There may be instances in which you would like to add them to an LMS, or other instances in which videos from the VEX server may be blocked by network firewalls or other restrictions. In order to provide access to the STEM Lab videos, we have supplied a shared Google Drive folder containing all of the videos from the EXP STEM Labs.
This article explains the contents and structure of the files in this folder.
Select this link to access the Google Drive folder.
Folder of VEX EXP STEM Lab videos opened in Google Drive. Inside there are folders corresponding to each STEM Lab.
When you open the Google Drive folder, you will see a folder for each EXP STEM Lab.
Folder of EXP Bucky Basketball videos opened in Google Drive. Inside there are folders corresponding to each Lesson.
Upon opening one of the STEM Lab folders, you will see a folder for each Lesson in the STEM Lab.
Folder of EXP Bucky Basketball Lesson 1 videos opened in Google Drive. Inside there are video files corresponding to each video in that lesson, and a folder of the lesson's Caption Files.
Inside each of the Lesson folders are the videos for that Lesson. They are listed in order as they appear in the Lesson.
Close up of an EXP STEM Lab video file to illustrate the naming system. The video's name reads EXP_BuckyBball_Lesson_2_4_Learn_DrivingTheCatapultBot.mp4.
All videos are named according to the same system. The sections of each video name are separated by underscores and are as listed in this example:
  • VEX Platform (EXP)
  • STEM Lab Name (BuckyBball)
  • Lesson Number (Lesson 2)
  • # of Video in that Lesson (4)
  • Lesson Page (Learn)
  • Name of Video (DrivingTheCatapultBot)
Folder of EXP Bucky Basketball Lesson 2 videos opened in Google Drive. Inside there is a folder named Captions and it is highlighted.
Caption files for each video are also included in a separate folder. They are provided in .srt and .vtt formats.
