Activating a License in VEX PD+
Welcome to VEX PD+! After you have purchased a license, you will receive access to the VEX Video Library,  1-on-1 Sessions, the VEX Educators Conference, and much more.
This article will walk you through the steps to activate your VEX PD+ license key so you can access all the features of VEX PD+.
Activate Your License
Black line drawing of an envelope
After you have purchased a license, you will receive an email from VEX Robotics with your license key.
VEX PD+ Login page with the Login link in the upper right corner highlighted
Next, go to pd.vex.com and select “Login.”
Page to login to an existing PD+ account with fields to enter email and password
Login using your VEX Account.
Don’t have a VEX Account? Fill out this form to register for a VEX Account.
Then navigate back to pd.vex.com after creating your account, and log in.
The VEX PD+ Dashboard showing educational resource links in the center and a highlighted navigation menu vertically on the lefthand side, where certain options are gray and locked and others, like the Community are bold and active.
Once logged in, you will see the dashboard. Because you have not yet activated your license key, some features will be locked.
The PD+ Dashboard, with the Activate License button on the lefthand side in the Quick Links category below the navigation menu highlighted.
Next, Select 'Activate License'.
Activate a license window with a field for entering a license key
Enter your license key, agree to the terms of use, and select ‘Activate.’
Close view of the user image window with first name, last name, and expiration date of the license
After activating a key, your licenses will be displayed with the type and end date of the license.
The PD+ Dashboard as a logged in PD+ user, with all options in the Navigation menu and Quick Links active and available. On the right side, the user name and expiration date is updated and visible.
You will now be able to select any of the Professional Development Offerings.
VEX PD+ Dashboard
When you select a menu item, such as the Community, you will have access to the content.
If you are having trouble logging in or need additional support, click here.
