Running a VEXcode V5 Competition Template Project on a VEX V5 Controller
Once you have created your project in the Competition Template, you can test the project on your robot using these steps. This is a great way to practice your autonomous routine or driver control strategy.
Need to create your project in the Competition Template? See these articles to learn more:
VEXcode V5 Toolbar with the Download icon highlighted in between the Brain and Run icons.
Begin by downloading your project to your VEX V5 Brain. Ensure that your Controller is paired with the Brain and turned on.
V5 Controller is shown with the Home menu open and the right arrow button highlighted.
Next, place the robot at its starting position on the field. On the Controller, select the right arrow to move the screen to the “Programs” option.
V5 Controller is shown with the Home menu open and the Programs option selected. The A button is highlighted.
Open the “Programs” option by selecting the A button.
V5 Controller is shown with the Programs menu open and the Competition Template project selected. The A button is highlighted.
Select your Competition Template project by selecting the A button.
V5 Controller is shown with the Compeition Template project menu open and the Run option selected. The right arrow button is highlighted.
Use the right arrow to move the screen to the “Timed Run” option.
V5 Controller is shown with the Compeition Template project's Start Match screen open. The A button is highlighted.
This will open the Start Match screen. You will see the breakdown of the match: 15 seconds for Autonomous and 1 minute and 45 seconds for Driver Control. Select the A button to start the countdown.
V5 Controller is shown with a Starting Match countdown, in this example it reads 2.
After counting down from 3, the match will begin.
V5 Controller is shown with the Autonomous portion of the match running. The screen shows the countdown and the current battery percentage.
The Autonomous portion of the match will automatically begin. The timer will count down from 15 seconds on the Controller screen.
V5 Controller is shown with the Driver Control portion of the match running. The screen shows the countdown and the current battery percentage.
At the end of the 15 second Autonomous portion, the 1 minute and 45 second Driver Control section will begin. The timer on the Controller's screen will count down.
Once the timer reaches 0, the project will automatically stop.
