Selecting a Starting Configuration in VIQRC Pitching In for VEXcode VR
To begin your VEXcode VR Pitching In Match, you can choose the starting position of Fling, the Hero Bot, with the starting configuration window.
Playground menu with starting configuration options for VIQRC Pitching In
Selecting a Starting Position
VIQRC Pitching In Playground showing robot starting configuration options in VEXcode VR
To open the starting configuration window, select the location icon in the Playground window.
VIQRC Pitching In Playground with starting configuration options for the robot
Here you will see the available starting positions for Fling.
Choose your desired Starting Position (A through H) by selecting the letter on the Field.
VEXcode VR Playground showing virtual robot starting configuration options for VIQRC Pitching In
Note: Fling's default starting position is Position F. To keep Fling in this position, select the 'X' at the top of the starting configuration window to close the window and maintain the default starting position.
VEXcode VR Playground showing the VIQRC Pitching In field, block workspace, and virtual robot starting position
Upon selecting a new starting position, the starting configuration window will close, and you will now see Fling in the selected position on the Field.
In the image shown here, Fling is now in Position A.
Changing the Starting Configuration
VEXcode VR workspace showing the VIQRC Pitching In Playground with Blocks and Python coding options
To change the starting configuration, select the location icon in the Playground Window.
VIQRC Pitching In Playground with the starting configuration selection menu open
Then the starting configuration window will open, and you will see Fling in its current starting position.
