Accessing the V5 Workcell Educator Certification Videos for Export
The videos in the V5 Workcell Educator Certification Course are an essential resource for educators. There may be instances in which you would like to add them to an LMS, or other instances in which videos from the VEX server may be blocked by network firewalls or other restrictions. In order to provide access to the videos, we have supplied a shared Google Drive folder containing all of the videos from the V5 Workcell Educator Certification Course.
This article explains the contents and structure of the files in this folder.
Select this link to access the Google Drive folder.
Google Drive Workcell Certification Videos folder is shown with sub-folders for each of the Units.
When you open the Google Drive folder, you will see a folder for each Unit of the Certification.
Google Drive opened to one of the Unit folders which has sub-folders for both of the videos.
Upon opening one of the Unit folders, you will see a folder for each of the two videos in the Unit: the video that demonstrates the activity for that accompanying STEM Lab, and a video for the facilitation of that activity.
Google Drive with one of the video folders opened and the .mp4 file is shown inside.
Inside each folder is the video for that Unit.
Google Drive with one of the video folders opened and the .mp4 file is highlighted.
All videos are named according to the same system. The sections of each video name are separated by underscores and are as listed in this example:
  • VEX Platform (Workcell)
  • Certification Unit (Unit 4)
  • Name of Video (activity)
Google Drive with one of the video folders opened and the Caption Files folder is highlighted.
Caption files for each video are also included in a separate folder. They are provided in .srt and .vtt formats.
