Using the V5RC Over Under Playground Window
The VEX Robotics Competition (VRC) Virtual Skills Playground is a virtual representation of the VRC Over Under (2023-2024) Competition Game. The Virtual Skills Over Under Playground Window is a space for a virtual version of this year's Hero Bot, Striker, to play VRC Over Under Virtual Skills.
V5RC Over Under Playground Window showing the field layout, scoring zones, and obstacles for robot programming activities
The Pre-Match Checklist
V5RC Over Under Playground field layout showing scoring zones, match objects, and robot starting areas in VEXcode VR
When you open the VRC Virtual Skills Over Under Playground Window, the Pre-Match Checklist will be open. To learn more about making selections in the Pre-Match Checklist, see this article.
How to Start, Stop and Reset a Project
V5RC Over Under Playground field layout with zones and scoring areas
Select the “Start” button to start a project.
This button will change to a “Stop” button when a project is actively running.
V5RC Over Under Playground field showing scoring zones, barriers, and starting positions in VEXcode VR
Selecting the “Stop” button will stop the project and the timer immediately.
The Score Window will appear at this time. See below for more information on the Score Window.
V5RC Over Under Playground Window showing the field layout, goals, and match elements used in VEXcode VR.
Select the “Reset” button to reset the timer, point value, and Field.
How to View Your Score and the Timer
VEXcode VR interface with the V5RC Over Under Playground window open beside the block-based coding workspace
Your score can be seen above the Field on the left side. This will be updated in real-time after the project is started.
V5RC Over Under Playground field layout with goals, barriers, and scoring zones for robot navigation and scoring.
The timer is located above the Field on the right side.
The timer begins when a project is started and counts down from 1:00. The timer will count down until “Stop” is selected, the [Stop project] Block is used in the project, or the timer reaches 0 seconds.
How to Use Match Loads
V5RC Over Under Playground field layout with scoring zones, barriers, and match elements for robot navigation and scoring.
Match Loads are available to place on the Field during a match. See this article about Using Match Loads in VRC Over Under for VEXcode VR for more information.
How to Retry and Close the Score Window
V5RC Over Under Playground field layout showing goals, barriers, and scoring zones.
The Score Window appears when the timer reaches 0, or if the project is stopped.
The Score Window shows your team's name, number, total score, and Skills Stop Time.
V5RC Over Under Playground Window showing the field layout, goals, and barriers for robot navigation and scoring.
"Submit Score" will send your team's score to the global leaderboard.
Note: The 'Submit Score' button will be available once score submissions are open for the 2023-2024 VRC season.
For more information about submitting a score for VRC Over Under Virtual Skills in VEXcode VR, view this article.
V5RC Over Under Playground field layout with zones, barriers, and scoring elements for VEXcode VR activities
Select the “Retry” button to return to the Field and reset the timer and score.
V5RC Over Under Playground field layout with key game elements and scoring areas in VEXcode VR
Select the “X” in the top-left corner to close the Score Window and return to the Field.
This will not reset the Field, timer, or score. It will return to the Field exactly as it was at the moment the project was stopped.
How to Expand and Shrink the Playground Window
V5RC Over Under Playground field layout showing goals, barriers, and scoring zones for robot navigation and gameplay
The window begins at a smaller size by default. If you want to expand the window, select the “Expand” button at the top left corner.
VEXcode VR Playground Window showing the V5RC Over Under field with the virtual robot and coding workspace
Select “Shrink” in the top-left corner to return the window to the default size.
How to Hide and Show the Playground Window
V5RC Over Under Playground field layout with goals, barriers, and scoring zones for VEXcode VR activities
Select the “Hide” button to collapse the VRC Virtual Skills Window. This will still keep the red toolbar at the top of the window visible.
V5RC Over Under Playground field layout showing scoring zones, barriers, and match elements in VEXcode VR
To view the full window again, select the “Show” button.
How to Select Different Camera Views
V5RC Over Under Playground field layout with scoring zones, barriers, and match elements for VEXcode VR activities
Select the “Top Camera” button to see an overhead view of the entire Field. This is the default view when you open the VRC Over Under Playground Window.
V5RC Over Under Playground field layout with scoring zones and match elements for robot navigation and programming
Select the “Chase Camera” button to see a behind-the-robot view.
V5RC Over Under Playground field layout with scoring zones, barriers, and match objects for VEXcode VR activities
Select the “Orbit Camera” button to see an overview of Striker and the full Field.
How to View Settings
Select the gear icon to open the Settings window.
V5RC Over Under Playground field layout with zones and game elements for robot navigation and scoring
In this window, your team's name and number will appear.
Data about your device will be displayed in the Settings window. This can be used to help troubleshoot any performance issues
