Using the Pre-Match Checklist in V5RC Virtual Skills
To begin your Virtual Skills Over Under Match, you must use the Pre-Match checklist to select your robot starting location, your robot starting direction, whether or not your robot has a preload, and the Field preload location.
For more information about Match Load Triballs, view the VRC 2023-2024 Over Under Game Manual and Appendix B - Robot Skills Challenge.
How to Choose a Starting Location
V5RC Over Under virtual field showing scoring zones, barriers, and obstacle locations for the pre-match checklist.
When you open the VR Virtual Skills Over Under Playground, the Pre-Match Checklist will be visible. The first item in the checklist is the starting location.
The default starting location is "E". To choose a different starting location, select the Edit button in the Pre-Match Checklist.
VEXcode VR with the V5RC Over Under Playground and a block-based project open for the pre-match checklist setup
Then select the letter that corresponds to the desired starting location.
How to Choose a Starting Direction
V5RC Over Under field layout in VEXcode VR showing zones, barriers, and scoring goals for the pre-match checklist
Select the Starting Direction box in the Pre-Match Checklist. Two arrow buttons will appear beside Striker.
VEXcode VR workspace with the V5RC Virtual Skills robot and block palette for the Over Under challenge
Select the arrow button to rotate Striker to face your chosen starting direction.
How to Select Robot Preloads and Field Preload Locations
V5RC Virtual Skills field layout showing starting position, scoring zones, and key field elements for the pre-match checklist
The Robot Preload setting defaults to 'Yes.' If you do not want to start with a preload, select the toggle switch to turn it to 'No.' The preloaded Triball will removed from Striker.
V5RC Over Under field layout used for Virtual Skills pre-match setup
To change your Field Preload Location, select the Field Preload Location Box in the Pre-Match Checklist, and then select the Edit button.
V5RC Over Under virtual field showing scoring zones and key field elements for the pre-match checklist
Next, select the number that corresponds to your desired Field Preload Location. Select the 'Done' button when you are finished.
How to Close and Reopen the Pre-Match Checklist
V5RC Over Under field layout used in VEXcode VR Virtual Skills, showing scoring zones, barriers, and game elements.
When you open the VRC Over Under Playground, the Pre-Match Checklist will be open. After you have finished making your selections, select the 'Begin Run' button to close the Pre-Match Checklist.
V5RC Over Under field layout used for Virtual Skills pre-match setup.
To reopen the Pre-Match Checklist, select the 'Starting Position' button on the left side of the Playground Window.
For additional information about using the VRC Over Under Virtual Skills Window, see this article.
