Understanding the VIQRC Full Volume Field Layout
Note: This article shows images from the 2023-2024 VIQRC Full Volume Field. The Field dimensions are the same for ALL VIQRC Virtual Skills Playgrounds, while the game elements on the Field will be different.
The Field in the VIQRC Full Volume Playground in VEXcode VR has the same dimensions and setup as the Field for an in-person Skills Match in the 2023-2024 VIQRC Full Volume Competition game. This information can be useful when creating projects for VIQRC Full Volume in VEXcode VR.
VEXcode VR workspace showing the VIQRC Full Volume Playground and block-based robot controls
Field Dimensions
Field layout showing dimensions, scoring zones, and starting areas for the VIQRC Full Volume Playground in VEXcode VR
Each full black square on the Field is 300mm by 300mm (~12 inches by 12 inches).
VEXcode VR workspace showing the VIQRC Full Volume Playground and block coding interface
Each half black square on the Field is 150mm by 300mm (~6 inches by 12 inches).
VEXcode VR workspace showing the VIQRC Full Volume Playground and block programming controls
The Field is 5 full black squares, and two half-squares long.
In total, the Field is 1.8m (~6 feet) long.
VIQRC Full Volume field dimensions and key measurements for setup and inspection
The Field is 7 full black squares, and two half-squares wide.
In total, the Field is 2.4m (~8 feet) wide.
Measurement Notes
VIQRC Full Volume field diagram showing dimensions and scoring zone locations for VEXcode VR
Each full square measurement begins and ends at the center of the black line on the Tile.
VIQRC Full Volume field layout showing dimensions and game element locations
Each partial square measurement begins at the center of the black line and ends at the inner edge of the wall.
VIQRC Full Volume field layout showing starting zones, goals, and game element positions in VEXcode VR
The total Field measurements begin and end at the inner edge of the walls.
