Accessing Help in a VEXcode EXP Python Project
Help explains what a command does so that you can figure out if it’s helpful for your project.
Accessing Help from the Tool Box
Select the Help icon on any command in the Tool Box.
You will see a screen extend from the right with information on the command selected.
Select any commands that you want to learn more about.
Hide the Help window when finished by selecting the right arrow next to the Help icon.
Accessing Help from the Workspace
Right click or long press on any command in the Workspace.
A context menu will appear. Select “Command Help.”
