Opening a VEXcode EXP Blocks Project on an Android
 Users can open a Blocks project in VEXcode EXP in different ways.
Open an Existing Project
VEXcode EXP Toolbar with the File menu open and the Open option highlighted. Open is the third option in the menu, below New Blocks Project and New Text Project.
Open an existing project by selecting Open from the File menu.
Previously saved VEXcode EXP project is visible from the device's files.
Then, use the Android interface to navigate and open your existing project.
Open an Example Project
VEXcode EXP Toolbar with the File option highlighted in between the Language and Tools options.
Select File in the Toolbar.
VEXcode EXP Toolbar with the File menu open and the Open Examples option highlighted. Open Examples is the fourth option in the menu, below New Blocks Project, New Text Project, and Open.
Select Open Examples in the drop down menu.
VEXcode Blocks Example Projects menu with a variety of projects across different categories to choose from.
Select a Template or an Example Project.
Note: Templates and Example Projects are used for the following:
  • Templates configure the motors and sensors on your robot for the project.
  • Example projects are premade projects that are ready to download and run.
VEXcode EXP with a template Example Project opened, including configured devices and a note with a description of the project.
Once selected, the Template or Example Project will open.
