Using Notes in a Blocks Project in VEXcode EXP
Here are some basic ways to manage notes in projects.
Adding a Note to a Project
VEXcode EXP Workspace Context Menu with the Add Note option highlighted. Add Note is the sixth option in the menu, below Undo, Redo, Clean up Blocks, Collapse Blocks, and Expand Blocks.
Right-click or long-press anywhere in the Workspace and select 'Add Note.'
Note in the VEXcode EXP Workspace with the text Type in the note added. Below are random numbers to show that numbers and symbols can be written too.
Then, type any text, numbers, or symbols into the note.
  • Press the “Enter” or “Return” key to write a multi-line note.
  • Select anywhere in the Workspace when the note is complete.
Collapsing Notes
Note in the VEXcode EXP workspace with the down arrow button in the note's top left corner highlighted.
You can collapse a note by selecting the down arrow in the top margin.
Collapsed note in the VEXcode EXP workspace that has been shrunk down to a smaller size and only shows a small amount of its text.
This will collapse the note.
Moving Notes Around
The top margin of a note in the VEXcode EXP workspace is highlighted, indicating that it can be selected and dragged to move the note around.
You can move a note by selecting the top margin and dragging it around.
Deleting Notes
Note in the VEXcode EXP workspace with the X button in the note's top right corner highlighted.
You can delete any note by selecting the 'X' located at the top right of the note.
Note in the VEXcode EXP workspace with its Context menu open and the Delete option highlighted. Delete is the second and last option in the menu, below Duplicate.
You can also delete a note by right-clicking or long-pressing on it and selecting 'Delete.'
Duplicating Notes
Note in the VEXcode EXP workspace with its Context menu open and the Duplicate option highlighted. Duplicate is the first option in the menu.
You can duplicate a note by right-clicking or long-pressing on it and selecting 'Duplicate.'
