Connecting with App-based VEXcode EXP to an EXP Brain - Android
It takes just a few steps to connect a VEX EXP Brain to App-Based VEXcode EXP on your Android tablet. Before beginning, make sure that you know the name of your Brain. For help naming your Brain see this article.
To Connect a VEX EXP Brain
Diagram shows a Battery being connected to an EXP Brain. An arrow indicates that the Battery should be slid into the charging port on the bottom of the Brain. The Battery is oriented with its latch facing away from the Brain.
Insert the battery into the EXP Brain.
EXP Brain with its Check button highlighted.
Turn on the EXP Brain by pressing the checkmark button.
VEXcode EXP application icon.
Launch app-based VEXcode EXP.
Android File Access prompt that reads Allow VEXcode EXP to access photos and media on your device? There are two buttons below, one reads Allow and the other reads Don't Allow. The Allow button is highlighted.
You may get a message asking you to allow the app to access your files. Select 'Allow'.
VEXcode EXP with the Brain icon on the Toolbar highlighted in between the Controller and Download icons.
Select the Brain button.
VEXcode EXP with the Brain dropdown menu opened and the Connect button highlighted.
Select 'Connect.'
VEXcode EXP Select a VEX EXP Brain prompt that has a list of EXP Brains to connect to. Only one Brain is listed in this example and it is highlighted.
A list of available EXP Brains will appear. Select the name of the Brain you want to connect to.
VEXcode EXP Select a VEX EXP Brain prompt that has a list of EXP Brains to connect to. The Brain has been selected and the Connect button below is highlighted.
Once a Brain is chosen, select the 'Connect' button.'
Brain screen is shown with an orange background and text that reads Bluetooth ID 0204. Below, an icon indicates that the X button can be pressed to Clear this message.
A 4-digit Radio Connection Code will appear on the Brain's screen
VEXcode EXP Radio Connection Code prompt that reads Enter the 4 digit Radio Connection Code displayed on the EXP Brain. Below, there is a field to enter the code and two buttons that read Cancel and Submit. The code 0204 has been entered into the field and the Submit button is highlighted.
Type the code into the prompt in the app and select 'submit'.
VEXcode EXP with the Brain dropdown menu opened after a Brain has been connected. The Brain's name in the menu is highlighted, and the Brain icon on the Toolbar is colored green.
The Brain icon will turn green to indicate it is connected. If you select the Brain icon, it will indicate the name of the Brain is it connected to.
To Disconnect a VEX EXP Brain
VEXcode EXP with the Brain dropdown menu opened. A connected Brain is shown in the menu, and the Disconnect button is highlighted.
Select ‘Disconnect’ to disconnect your EXP Brain from VEXcode EXP.
Connection Issues
