The GO Competition Playgrounds in VEXcode VR use a virtual version of the Competition Advanced Hero Robot from the VEX GO Competitions. Depending on the Playground, the robot is either the Competition Advanced Hero Robot 2.0 or the original Competition Advanced Hero Robot.
Each virtual robot has the same dimensions, motors, and sensors as the physical robot it is based on. The two robots are coded with the same blocks and work the same way, but they are built differently.
To turn a GO Competition Playground into a class competition, open its game in VEX Classroom Games:
- Mars Math Expedition
- Ocean Science Exploration
- City Technology Rebuild
- Village Engineering Construction
The Competition Advanced Hero Robot 2.0, used in the GO Competition – Mars Math Expedition 2.0, Ocean Science Exploration 2.0, City Technology Rebuild 2.0, and Village Engineering Construction 2.0 Playgrounds, has:
- Two front wheels, one on each side, and one center rear wheel.
- A Front Eye Sensor mounted under the forks, on the Arm, facing downward.
- Longer front forks for manipulating objects.
Because the Front Eye Sensor is mounted on the Arm, it moves up and down whenever the Arm moves. Changing the position of the Arm changes the position of the sensor, and can affect what it is able to detect on the Field.
The original Competition Advanced Hero Robot, used in the GO Competition – Mars Math Expedition Playground, has:
- Four wheels, two on each side.
- A Front Eye Sensor fixed to the front of the robot, facing forward.
- Shorter front forks for manipulating objects.
Because the Front Eye Sensor is fixed to the robot, it stays in place when the Arm moves. When the Arm is lowered, the sensor sits between the forks.
Features of Both Robots
Both robots drive and turn using a drivetrain, which you code with the Drivetrain blocks.
The drivetrain includes a Gyro Sensor that tracks the robot's heading from 0 to 359.9 degrees, with clockwise as positive. This helps the robot make accurate turns, and it can also detect when the robot crashes into something.
The Arm uses its forks to lift and lower game objects and field elements, and you move it with the ArmMotor blocks.
The Arm starts in the lowered position and can move from 0 degrees (lowest) to 420 degrees (highest).
The Front Eye Sensor, called FrontEye in the Toolbox, can tell whether an object is in front of it. It can also report the object's color, brightness, and hue.
