Using Example Projects with the GO Competition - Mars Math Expedition Playground
Example projects provide students with an easy way to get started learning how to use different blocks to complete the tasks on the GO Competition - Mars Math Expedition Playground.
What are some of the Mars Math Expedition Playground Example Projects?
VEXcode VR workspace showing an example GO Competition block project in the Mars Math Expedition Playground
Example projects are provided for each aspect of game play, such as tilting the Solar Panel and clearing the Landing Site.
Getting Started Using Mars Math Expedition Example Projects
VEXcode VR workspace open to the Mars Math Expedition Playground with an example project ready to run
To open an example project, select the File menu.
VEXcode VR workspace with an example project for the Mars Math Expedition Playground and the GO robot on the field
Select 'Open Examples.
VEXcode VR workspace showing the Example Project blocks for the GO Competition Mars Math Expedition Playground
Select an Example Project. The Mars Math Expedition Playground Example projects feature the VR Competition Advanced Hero Robot in the icon.
Example project open in VEXcode VR for the GO Competition Mars Math Expedition Playground
Once the Example Project loads, be sure to select the correct Stage on the Playground to ensure it runs properly. The note in the project will include the Stage. For more information about how to select the correct Stage in the playground, see this article.
Using Mars Math Expedition Example Projects with Students
Using example projects allows students to get started coding right away on the GO Competition - Mars Math Expedition Playground. Once an example project has been selected, the following steps will support your students as they learn to code the VR Hero Robot to complete tasks and earn points.
VEXcode VR showing the Mars Math Expedition Playground with a GO robot and an example blocks project open
Step 1: Open an example project, making sure to select the correct Stage. Run the Example Project for Students.
Guide students to open the GO Competition – Mars Math Expedition Playground, select the correct Stage, and press the Start button to run the example project. Have students observe the behaviors of the VR Hero Robot, and talk about how they relate to the example project.
Mars Math Expedition example project open in VEXcode VR block-based workspace
Step 2: Modify the example project to make it your own.
  • Encourage students to think about the particular aspect of game play demonstrated in the example project, and how they could change the code to complete tasks and earn points on the Playground.
  • Students should choose one thing to change at a time, so they can see the direct effects of their changes. Remind students to run their projects frequently to see how each change affects the behavior of the robot.
  • Students can continue modifying projects in this way many times, observing the results of the changes they are making and using this information in order to improve their ability to complete game tasks and earn points.
  • For additional information on the use of any block or command, access the Help section by clicking on the question mark in the upper right corner of the workspace.
VEXcode VR Playground showing the Mars Math Expedition field with a GO robot and example blocks loaded
Step 3: Experiment with another example project or try your own.
After students have iterated on one example project several times, they may be ready to use what they have learned to create their own projects, or to remix another example project to continue to improve their coding.
