Using the Playground Features in the GO Competition Playgrounds
The GO Competition Playgrounds in VEXcode VR let students code a virtual VEX GO Hero Robot to complete the tasks from the VEX GO Competitions. There is one Playground for each VEX GO Competition Field, and Mars Math Expedition has two: the GO Competition – Mars Math Expedition Playground uses the Competition Advanced Hero Robot, and the GO Competition – Mars Math Expedition 2.0 Playground uses the Competition Advanced Hero Robot 2.0. For additional context on each competition, including introductory storybooks, competition tasks per Stage, and more, see the accompanying STEM Lab Unit:
Each Playground has four Stages, and each Stage adds new tasks to score. To learn what scores in each Stage, see the article that introduces your Playground:
To turn a GO Competition Playground into a class competition, open its game in VEX Classroom Games:
The four GO Competition Playgrounds in the VEXcode VR Playground menu: Mars Math Expedition, City Technology Rebuild, Ocean Science Exploration, and Village Engineering
This article covers the features that are specific to the GO Competition Playgrounds. The buttons that every VEXcode VR Playground has are grouped under Standard Playground Buttons, near the end.
Selecting a Stage
Select Stage menu with Stages 1 through 4, shown when a GO Competition Playground opens
When you open a GO Competition Playground, the Select Stage menu appears.
Select a Stage to load its Field.
Location button highlighted in the upper left corner of the GO Competition Playground Window
To change the Stage, select the Location button in the upper left corner of the Playground Window.
Select Stage menu with the Stage 1 to 4 buttons highlighted
Select a Stage from the Select Stage menu.
You can change the Stage at any time this way.
Checking the Score and Timer
Score and timer bar highlighted at the top of the Playground Window, showing Score 1, Autonomous Coding Skills, and 00:42
The bar at the top of the Playground Window shows the score and the timer.
The score updates as the robot completes tasks. The timer counts down from 1:00 once the project starts, and the run ends when it reaches 0:00.
Viewing the Game Results
Game Results window in a VEXcode VR GO Competition Playground showing Stage 1 Points Scored, Get Certificate, and Try Again
When the timer reaches 0:00, or when you select Stop, the Game Results window shows the points scored on that Stage.
Select Try Again to reset the Field and run the same Stage again.
Get Certificate becomes available once at least one point is scored.
These buttons work the same way in every VEXcode VR Playground.
The bar at the top of the Playground Window has the Expand, Hide, Activities, and Close buttons. To learn about them, see Using the Playground Window in VEXcode VR.
Start and Reset buttons highlighted in the lower left corner of the Playground Window
Select Start to run your project. While the project runs, Start changes to Stop.
Select Reset to reset the Field, the score, and the timer.
Menu and Download Playground buttons highlighted in the upper left corner of the Playground Window
Select Menu in the upper left corner, to hide or show the buttons below it.
Select Download Playground, below the Menu and Location buttons, to save an image of the Playground Window as a .png file. The image shows the robot, the game objects, the score, and the timer at that moment.
Top Camera and Chase Camera buttons highlighted in the lower right corner of the Playground Window
The Camera buttons in the lower right corner control your view of the field.
Select Top Camera for an overhead view of the whole Field.
Select Chase Camera for a 3D view from behind the robot.
Navigation Kit highlighted in the lower right corner of the Playground Window
Use the Navigation Kit, in the lower right corner beside the Camera buttons, to place waypoints on the Field and see the distance, angle, and coordinates of each one. This helps when planning the robot's path.
To learn how, see Using the Navigation Kit in a VEXcode VR Playground.
Mars Math Expedition: Helicopter Button
Helicopter button highlighted in the lower right corner of the Mars Math Expedition Playground Window
The Stage 3 and Stage 4 Fields of both Mars Math Expedition Playgrounds include a helicopter that can be placed on the Landing Site once the debris is cleared.
You complete this task with the Helicopter button in the lower right corner of the Playground Window.
Grayed-out, inactive Helicopter button in the Mars Math Expedition Playground
The Helicopter button is inactive until the debris is cleared from the Landing Site. While it is inactive, the button is grayed out and can't be selected.
Cleared Landing Site and the active Helicopter button highlighted in the Mars Math Expedition Playground
The Helicopter button becomes active once the debris is cleared from the Landing Site, as shown here.
Select the Helicopter button to move the helicopter onto the Landing Site and score the point.
This screen recording shows one example of how this task can be completed.
Village Engineering: Build House Button
The Village Engineering Construction Playground starts with three house components on trailers at the far end of the Field: the Brown Walls, the Gray Walls, and the Roof. To build the house, move all three components onto the red tile.
You complete this task with the Build House button in the lower right corner of the Playground Window.
The Build House button is inactive until all three house components are on the red tile. While it is inactive, the button is grayed out and can't be selected.
The Build House button becomes active once all three house components are on the red tile, as shown here. The components can be stacked or side by side.
Select the Build House button to build the house on the red tile and score the point.
Village Engineering: Process Crops Button
Village Engineering Construction Stage 4 Field with the Crops and the Food Processor highlighted.
Stage 4 of the Village Engineering Construction Playground adds the Crops and the Food Processor. To score, deliver a Crop to the Food Processor tile, then turn it into Food.
You turn the Crop into Food with the Process Crops button in the lower right corner of the Playground Window. The robot cannot press the Food Processor itself.
The Process Crops button grayed out in the lower right corner of the Playground Window.
The Process Crops button is inactive until a Crop is on the Food Processor tile. While it is inactive, the button is grayed out and can't be selected.
A Crop on the Food Processor tile, with the active Process Crops button highlighted.
The Process Crops button becomes active once a Crop is on the Food Processor tile, as shown here.
The Food Processor after the Crop has been turned into Food, with the green Food beside it.
Select the Process Crops button to turn the Crop into Food and score the point. Deliver the Food to the red tile to score another point.
